- Jul 27, 2017
- 22
- Plaster
- Pentair Intellichlor IC-40
I've seen old threads on this topic but was wondering if anyone has more current information.
I recently installed an early model Levolor that had been sitting around for several years. The sensor and cable looked new at the time, but the sensor seems to have failed after just a few months. I disconnected the sensor wires at the box and the sensor light correctly came on. I assume the sensor has shorted inside.
From past threads, it appears these sensors are subject to failure and the only solution is to install a new one with attached cable. I was hoping to avoid pulling cable through a conduit again, but Jandy tech support said that part# S2044 (sensor w/o cable) is not available.
The attached picture shows a small separation has developed around the cable. The sensor is velcro'd to the wall tile, not in the skimmer.
Do you know if Jandy has improved the design? A picture on Amazon refers to 'Style2' half-moon and shows a small sleeve on the cable as it enters the sensor. Mine does not have that sleeve and I'm wondering if that is how moisture may have entered the sensor and shorted it.
Has anyone found an alternate / less costly solution for a bad sensor? Thanks in advance for any feedback.
