I have been reading on the forums, lots of knowledge in this site, however I couldn't find anyone with a newer pump controlled by an older Jandy RS system like mine
The pump is hardwired to the power and it's controlled by it's own panel on a timer, has been working great since install 4 years ago
To use the spa I use the quick clean button on the pump's panel which is set to run for 2 hrs and push the spa button(to rotate intake valve) and heater on the pool control panel
I have a RS4 control panel inside the house that controls all functions of the aqualink and I wish I could turn the pump on as well.
I connected the pump's serial cable to the aqualink and i thought that would work but of course...not
I am understanding that the pump either work from it's own panel or it must totally be controlled via serial cable from the pool control panel
I am also understanding that my aqualink is old and does not have the capabilities to control a variable speed pump
I'd like to know if there is any workaround to turn the pump on with an older aqualink(6474G)
if not which revision of panel will be able to control my pump(possibly a list of various revisions and capabilities), and how to program it
and if I will need to replace my RS4 control panel inside the house
Thanks
Thanks
