Well, here it is in all its splendor and glory! As of about 11am it is Done! And we'll likely never get to use it. [sigh].
It needs to cure for 7 days, absolute minimum of 5 days. For every day that it rains you add one day to the cure time.
Given that the next 4 days are in fact showing perfectly optimal, and going off the extended forecast, I think we'll be adding water a week from Thursday (5/14).
But the adventure isn't over yet! If the cement and/or paint are going to fail, I think we'll see it within one month from when the water is added. So mid June will tell us if we found the "cheapey" route for a short term fix or if it was a miserable failure. Between now and then I'll be adding up man-hours and our expenses to report.
After the pool has ran for a day or two we will be replacing the sand in the filter. (Or should we do it sooner?)
Next on the list is
1. replacing the in-pool light.
2. Then on to finding the leak within the pipes. Anyone ever had their pipes sleeved? Anyone ever sleeved their own pipes?
3. War-gaming what to do about the skimmer (and return) in the shallow end that needs to be moved down about 3"-6". (That'll be fun. Not!)
Sorry about the cadywompus picture. I take what I can get!
