Hi all. My first post here, although I've been around since July 2020 reading. Lot's of good info on this forum, and I thank you for all of it. It's been a big help!
We have an above ground 24' pool, 7 years old, purchased in 2016 (our 2nd 24' above ground).
So the last 2 years we've fought with algae. Brown patches on the bottom and greenish around the bottom edges. You'd think it would go away, and it seemed to after brushing and slamming it, but it always came back. Backwash was also milky. Seemed I spent a fortune in bleach and chemicals - and I did.
So this year, early on we noticed a leak. Not sure where it was coming from but leaking nonetheless. So, we replaced the liner. With fresh water, algecicde, and 2 gallons of bleach we covered it in February (solid cover).
First weekend of May we pulled the cover off. Water was crystal clear. So, having a sand filter we replaced the sand, rinsed, added bleach water in the filter (no sand), and let it set for several hours. Drained, filled it with 150 pounds of filter sand. Replaced the hoses, new 1 HP pump, and new steps. Last steps had 40 pounds of sand in them for weight, which I suspected had algae in them as well, so we bought new ones - no sand this time, but 2 - 40 pound weights to weigh them down. Basically everything except the pool frame is new. Tested the water and of course everything was off. Started with algaecide, 2 pounds shock (Turbo Shock by Pool Life, 78% calcium hypochlorite - wife wanted to switch back from bleach), and began getting the CYA up gradually. All is well for the time being.
Until now.
Yesterday I back-washed after vacuuming, and the backwash was milky, very milky. Beginning to see some brown spots in the bottom also. Not sure what I'm doing wrong. Added 2 pounds shock yesterday evening.
Here's the test from today (Taylor K2006C):
Water Temp - 76 F
Hardness - 160
Ph - 7.4
Alkalinity - 90
Total chlorine - 5 ppm
Free chlorine - 3 ppm
CYA - 35
Any help is appreciated. About at my wits end. And thanks in advance.
Buddy
Until now.
Water Temp - 76 F
Hardness - 160
Ph - 7.4
Alkalinity - 90
CYA - 35
Buddy
