V-Green EVO 165 is the correct Century VS motor for that impeller. Do you have automation? If not, the Nidec Neptune NPTQ 165 will give more control over speeds and programming for about the same cost.Not pool in signature:
Want to upgrade a Pentair Whisperflo to a
V-Green vsp. The current motor labels are pictured, also will the wet end be fine the way it is with the original impeller or does it need to be changed to be compatible.
Thanks in advance,
AllanView attachment 529714View attachment 529715
To get the benefit of a larger motor you need to also change the impeller. This CMP aftermarket one is very good (their aftermarket Pentair parts are actually better than OEM):Thanks @1poolman1, Was hoping to get a 2.7-3 hp vsp on there. No automation at all.
The frame is the diameter of the motor casing. The "Y" indicates is has a square flange. NPTQ270 is what you need for a Whisperflow pump.@1poolman1, Thanks, Exactly the info I wanted. Which one has the y56 frame. I'd rather spend the extra $70-80 up front for the impeller and make it on the back end by efficiency.
