Did a BYOP here in Austin Texas. 5600gal pool with a 1000 gal spa.
I grew up with a backyard pool I helped maintain, was a lifeguard at a public pool and helped with it, and I have a MS in environmental engineering so know a tiny bit of chemistry. It's a small, relax out of the heat pool in our small yard. 90% of the time it will just be the 4 of us using it.
Whole thing is Pentair including:
Intelliflow3 VSF
Intellicenter i8PS - w/2x Intellivalves
Pentair MasterTemp
Pentair Clean & Clear Plus CCP420
Autofill
Pentair Rainbow 320 In-Line Chlorine/Bromine feeder
Blower on the spa side.
Quartzscapes - mostly white in color (marine blue or something)
After an hour long wait time and 20 minutes of actual trouble shooting, I think I have the pump working and the valves correct. For right now I have the valves set to 6 for pool and 24 for spa. I've got the pump running at 45GPM as I am supposed to run it non stop for 72 hours.
Before the problems - we did overfill the pool by about 2 inches. It's 105 outside, so I was thinking evap would sort that out the next couple days, but if I need to remove the extra, let me know.
Problems(?)
1. When I first started it had a horrible air leak and could not get close to primed. 2-4 inches of air in the pump chamber. I figured out that the pipe from the 3 way was not glued in. Glued it and now I can get a prime (full chamber) but no vacuum showing at the pump/chamber. I also get the sound of air moving through the system, after the filter. I have burped the filter. From the filter through the heater and back down to the ground I can hear water moving with the sound of air/bubbles and I am getting bubbles from some of the returns. After 30 minutes I had two bubbles in the pump chamber, about the size of a half dollar. Both stuck to the bottom of the clear top.
Give the air sound in the pipes, the bubble or two in the chamber, bubbles from the return - is it possible I still have an air leak? Something I need to hunt down? or is the first 30 minutes too soon to be worrying about having all the air out of the system (3" pipe and equipment 70ft away from pool).
2. Just back from Leslie's - As expected high pH (8.7), but Austin city water is 8.5+, so just battling that and normal high pH from the first days post plaster. I measured my Ta at 70, Leslies says 62. I added 32oz of acid, so will get again in an hour or two to see pH and TA are back in check.
There is no Cl (FC = 0.8ppm; TC 1.42). Start up says not to add it to the autofeeder. Can I just throw a tablet in the skimmer? Do I need to buy liquid Cl for now, save tablets for later?
They told me I should also address my low CyA (5ppm) using their Conditioner. (add 2lbs). The rest they said could wait.
FC - 0.18pppm
TC - 1.43
pH 8.7 - added 32oz 32%ma
TA - 62
CH - 87ppm
CA - 5ppm
Iron - 0
Cu - 0.2ppm
Phosphates 424 ppb
TDS - 300ppm
Closing -
For now, as we get the above sorted out - where do I find best practices for setting up the pool in general (how long and how often to be running pumps, how best to setup auto feeder, etc) - Is that all in the pool school?
Intelliflow3 VSF
Pentair MasterTemp
Autofill
Problems(?)
FC - 0.18pppm
TC - 1.43
TA - 62
CH - 87ppm
CA - 5ppm
Iron - 0
Cu - 0.2ppm
Phosphates 424 ppb
TDS - 300ppm
Closing -
