I make this tutorial to help others with replacing the bearings. I do not take responsibility of any damage be done to the parts.
All right. First thing you have to do is remove the old bearings ( I used bearing removal tool) and put new ones on. Before you put the new bearings on snap E clip on both sides of the shaft. They act as a stop for the bearings. Now put the new ones on as close to these clips as possible.
Then place two red spacers inside front bearing housing
Next slide in the shaft into front bearing housing
Next slide on coil housing over the shaft and make sure front bearing housing tab and coil housing notch align
Then slide on black and red spacers on the rear shaft
And then rear bearing housing
After that bolt on the bearing housing to the bottom of the case
Next what you want to do is to remove the black plastic piece in front of the pump by removing 3 screws from it
This will help you a lot with putting on the 3 long screws that holds both bearing housings together.
I used my cordless DeWalt drill and I set up the clutch on 7 . This way it bolt on the long screw tight but it did not damaged screw head.
Next put the black piece back attached to the front of the motor using 3 screws.
Then slide the clear plastic impeller on the back of the shaft. Slide it on enough so you will be able to place the E-Clip on the front of it. ( I forgot to take a picture of it but check the photo below. I marked the plastic housing that goes over the impeller.DO NOT PUT THE IMPELLER HOUSING BACK ON YET!!!! )
After you slide on the impeller snap the E-Clip in front of it.
Next install blue plastic piece with tube outlet in it on the front of the motor. But before you do that place the rubber gasket on the shaft.
Next screw on the front white impeller wheel. Screw it on with one hand and use other one to hold the back impeller. After that place back impeller housing back on
The next step will allow you to install bottom bolts on the front blue impeller wheel housing.
Rotate the housing with outlet tube 90 degrees . It might be little tight and you might use some force to do that
After you place the bolts and nuts on the housing rotate it back so the outlet tube is pointing upward. Bolt on everything together. And do not forget to place ground cable in the back of the housing
Here is the image of the bearings I used
This is not he best tutorial but it might help somebody. If you have more question do not hesitate to ask.
Good Luck
Good Luck
