- Jul 9, 2021
- 4
- Plaster
- Pentair Intellichlor IC-20
New install August 2022 and this is my 1st pool. The unit seems to struggle to keep an FC level of 2.0 ppm. Unit is set at 80%. I have been adding liquid CL to boost the FC level.
Recently was away for 10 days and found mustard algae upon return. Pump was left on during my absence. Based on what I have learned reading TFP forums it seems the FC is too low overall.
Pool size is 13,000 +/- gallons
Wet Edge finish
Pentair Clean and Clear Cartridge Filter 100 sqft.
Pentair VS pump which is run 12 hrs/day @ 2,000 rpm
Pool gets full sun from about 10 am to 7 pm
Pool is inside a cage
Recently been having high levels of pollen in SWFL.
TA - 100 ppm
pH - 7.4 - 7.8 typical range based on daily testing
CH - 350 ppm
CYA - 50 ppm
Salt - 4,000 ppm
Using Taylor kit K2006C for all except salt which is a digital meter reading.
Questions
1. Is the IC20 working correctly and is this unit large enough? I have been cleaning the unit monthly to remove buildup on the plates.
2. What should the FC level be to better avoid an algae issue?
Any suggestions or comments would be welcome. I have done the slam to clear the mustard algae and the pool looks to be back to a normal appearance with no CC. Just allowing the FC level to drop to the normal range.
Many thanks
Wet Edge finish
TA - 100 ppm
CH - 350 ppm
CYA - 50 ppm
Salt - 4,000 ppm
Questions
Many thanks
