intelliChlor IC-40 during winter
Ame
0
May 22, 2013
109
Phoenix Arizona
I dont close my pool in the winter Im in Arizona. SO water wont freeze. My intelliChlor IC-40 wont produce Chlorine in winter though. I think it stops at temp somewhre between 50-60 degrees? So DO I add floater and trichlor or dichlor during the winter? Does anyone take the intelliChlor IC-40 out of the loop during the winter? I saw some mentioned taking it out and replacing with a straight pipe in its place. Does intelliChlor IC-40 make such a thing?
A,
I have three saltwater pools here in Texas and my IC40 cells stay in place all winter and I have never had an issue.
The cell shuts off when the water temp drops below about 52 degrees.
I use liquid chlorine in the winter as pools use very little FC when the water cold and the sunshine is less.
A,
Thank you that what I've been doing too! I just wanted to make sure I'm doing what others do that don't need to shut down their pools in warmer climates. Thank you Jim
Reactions: Jimrahbe
