- Dec 25, 2021
- 91
- Plaster
- Pentair Intellichlor IC-40
I'm putting in the IntelliCenter along with some microbrites. The Intellicenter I am waiting for has a built in load center but the manual is lengthy and believe it or not Pentair customer service isn't all that helpful so that leads me here.
When I bring in my wiring for the IC load center does it have an on/off breaker built in? If not, do I need a specific brand? Every panel I've seen is a Siemens, Square D, GE, Eaton etc etc so they only fit the specific brands that work with it.
Follow up on this question the additional breakers for say the pump etc, which brand are they? I figure GFCI, of course, but any additional information would be very helpful.
In the case of the MicroBrites, is there a specific Pentair transformer that I should use or can I get away with a Home Depot $50 landscape transformer?
Follow up on this question when having the IC control landscape lighting or backyard low voltage lighting may I use a transformer other than a Pentair or am I locked in for life for those?
Thank you
Thank you
