tcat
- May 30, 2012
- 1,619
- Plaster
- CircuPool Edge-40
I seldom take it out. I sometimes wipe it off when I clean the basket
I run my pump at 2500 for an hour in the morning, then 1750 for 10 hours. I have flow 50% drain, 50% skimmer. Got stuck occasionally, so I put a bumper on the skimmer. Runs fine now.Just got the se plus this week. Still trying to figure out how to set my vs pump. Above 2000 rpm the robot gets stuck in the deep end wall. It seems like the returns are making the current to strong for the bot. If I drop it down to 1700 rpm it can do it's job. I just like more circulation in my pool though. It looks like it's doing a great job so far when it can run.
When/if the lights on the Betta turn red, charge it. My charger light is red for about 2.5 hours, then turns green when fully charged. You might send support a message.The light on the charger is supposed to turn red when charging correct? Mine has been running non stop since I bought it, and everytime I try to plug it in the charger light is always green. Don’t know if it’s always fully charged or if there is something wrong with it…
I adjusted my returns so they have a more shallow angle towards the surface. Seems to have done the trick.I run my pump at 2500 for an hour in the morning, then 1750 for 10 hours. I have flow 50% drain, 50% skimmer. Got stuck occasionally, so I put a bumper on the skimmer. Runs fine now.
