Hi,
What's the best way to install returns in an IG gunite pool? I'm redoing the plumbing in a 60's era pool and I'm adding at least 4 returns, maybe 7, depending on if I tie into the two old 1 1/2" copper returns. I want to have good circulation in a pool running 24/7 at low speed.
Do I need a core drill or not? What about drilling holes around the circumference and chipping it out? If I'm using a core drill and running 2" pipe do I cut a 2" hole? How does the core drill anchor to the pool wall? If it's bolted in how is that done and how do you fix those holes? How do you seal the hole? I want directional fittings where should the end of the pipe be to the pool wall, etc.
If you tell me to use 2 part epoxy is that something like AB putty?
Obviously I'll appreciate any advice from your experience.
Repairman
Repairman
