I opened up my inground swim spa and found that my two speed waterway pump was seized and had to be replaced. To preface I have a hydroquip 8000 RHS system with M7 probes and a top sizer controller. Unfortunately I found out that they don’t make the waterway two speed pump anymore, called hydroquip and they recommended the two speed LX pump. I bought it and replaced the pump, and when it cycles on the low speed it thinks that there is a flow issue because the M7 temp sensors sees two big of a temperature difference.
The only other thing I think it can be is a leak in the suction side, I have a very small air bubble at the top of the new pump. No pipes are leaking and I checked joints with soapy water, I’m stumped.
I saw someone else on this forum, couple years back have the same issue was wonder on any suggestions.
Mike
Mike
