Hello Community!
First, I would like to thank you for sharing your knowledge and wisdom. I appreciate having these forums as a resource and have done extensive research and reading while on my quest to conquer a recurring issue I'm having. Thank you in advance for your helpful comments and suggestions!
The Problem:
We have several cabins in the Smoky Mountains with indoor swimming pools. They are small so perhaps "plunge pools" would be more appropriate. Every few months the pools become cloudy and I get a phone call from the management company telling me they can't figure out what is wrong. I make the drive up there and always find the same thing.
The Levels:
Typically, adding shock and muriatic does nothing. I've tried different types of chlorine and other products that have been recommended to me in the stores which do nothing. I have called "professionals" for help who can't figure it out either, so, I end up throwing in a sump pump and draining the water.
At first, I tried draining a quarter of the pool. When that didn't work, I tried half. After a lot of time and effort, I just started draining and refilling the entire thing. After doing this several times, I decided it would be a good idea to see about automating the pool chemistry maintenance. A local company talked me into adding automatic chlorinators to every pool, which I did. Guess what? It's still a problem!
Here's What [I think] Is Happening
My Questions
The Problem:
The Levels:
- = 0 ........... Total Chlorine
- = 0 ........... Free Chlorine
- > 240 ....... Alkalinity
- > 8.4 ........ pH
- > 300 ....... Cyanuric Acid
- We are adding stabilized chlorine to indoor pools
- Indoor pools don't have to worry about the sun burning up the chlorine
- Cyanuric acid levels build up causing the pool to lock up [but no one knows this]
- We add more and more chemicals which take no effect
- Cyanuric acid levels continue to climb
- TDS exceeds the point at which water can be chemically treated
- We have no choice but to drain and refill
Myth #1: “Chlorine is Chlorine, it’s all the same.”
There are 5 types of Chlorine; Sodium hypochlorite, Lithium hypochlorite, Calcium hypochlorite, Dichlor, and Trichlor. The first difference is Sodium, Lithium, and Calcium are un-stabilized Chlorine. Dichlor and Trichlor are stabilized. Stabilized chlorines have Cyanuric Acid which acts as a type of sunblock for the Chlorine. The sun will break down Chlorine causing it to burn off quicker; Cyanuric Acid slows this process down. Therefore, Dichlor and Trichlor are used in outdoor pools as pucks/tablets. Because indoor pools do not need to worry about the sun, and do not need Cyanuric Acid, they usually use the other 3.
My Questions
- Am I on the right track?
- Will switching to NON-STABILIZED chlorine help solve the problem?
- If so, where can I find this product for in-line feeders? Most products online don't provide all the details needed to make a decision on what type of chlorine it is.
