We got an above ground 16×48 Coleman pool last summer and due to various reasons... we never got to put the cover on it last year. This year, we had a lovely putrid green swamp, complete with a dead bird and large dragonfly larvae. We drained it, pressure washed it, sprayed it with bleach and scrubbed. Refilled and installed a 12 inch Intex sand filter.
My problem is: Before installing the sand filter pump, everything was good. After the new pump was set up, we got what we thought was sand blowing back into the pool. When I touch it, it isn't sand. It just puffs and disappears. From what I see, we need to scrub and vacuum to waste - which I'm in the process of trying to find a vacuum. Not only that... but my chlorine is disappearing literally over night. I could put in a whole bag of shock and my chlorine test (I have the 5 way Poolmaster test kit) will show very high levels, but it's gone within a day. My pH stays at 7.2 (added 1/2 cup of baking soda last night and it went up a level but is back down today) but my acid demand test is really confusing me -- my test says to use the same water from the pH test and to add drops of #3 until it reads at the desired level... but my drops make my water turn yellow/orange, the lowest levels on the chart. My alkalinity test came to me adding 10 drops, which according to my test booklet is sufficient.
So we've got an above ground pool that is in direct sunlight and cannot keep a chlorine reading, even after shocking 3 days in a row. Alkalinity is okay, but pH stays kinda low. I went to a local pool store and they said to shock for 5 days and add 1/2 lb baking soda everyday for 4 days.
I'm confused about all of this and it's really, really frustrating that I can't seem to figure this out. My water is crystal clear and not cloudy, but we haven't even been able to swim yet because we're having trouble getting the water balanced. On top of that, it's impossible to find chlorine tablets or shock or even jugs of liquid chlorine here (Western NC). I'm ready to just close the pool for summer. Can anyone advise on what I should do? Or can you suggest an affordable vacuum?
