- Apr 2, 2022
- 802
- Plaster
- Pentair Intellichlor IC-40
Since my IC40 started up it has consistently measured salinity ~500ppm under the Taylor drop test. It hasn’t been an issue until now as the pool builder dumped too much salt in at the start up. I also thought the variance would narrow as the water warmed up.
As it’s slowly come down with lots of rain and overflow, it finally bit me.
We went on vacation and I checked the pool chemicals before we left, then bumped up the cell to a bit higher percentage just in case. The cell read 2800 at the time vs 3400 for the Taylor and I didn’t think anything of it. By the time we got back from vacation the cell was reading low salt and the Fc in the pool had dropped to 1.0 with a cya of 70.
I managed to catch the very beginning of an algae issue and a SLAM took care of it (passed two OCLT). Added more salt and cell is happy again.
But it still reading 600ppm too low, and to keep it happy means having a salt level the family can definitely taste.
I tested the thermistor per the FAQ here and it returned an accurate temp reading, so I’m at a loss.
Is a 600ppm difference too much? And if so what could be going on with the cell if the thermistor is returning an accurate temperature?
If I need to make a warranty claim, can I call Pentair directly? My PB says everything must go through him but I’m leery of that because I don’t want to deal his “I told you so salt cells are nothing but trouble” diatribe again.
All thoughts appreciated !!!!
Brian
Brian
