Good afternoon,
I want to add an in-ground spa to my pool. I think an average-sized one, which can fit about 4-8 people max. I attach below the pictures of the pool (forget the dirt from the trees, I need to pressure wash it asap). The picture with the measuring tape indicates the corner of the pool where I would like to have the spa. There is 13'5" in the shorter direction toward the pool enclosure. In the other direction, we have plenty of space cause I can always move the couches. I would like it to have a spillway to spill water into the main pool. I would probably use gas to get it hot quickly (I dont have a gas line in my house). I have a few questions:
1) I think it would be good to use the same recirculating pump as the pool and have that spillway from spa to pool. Is that a bad idea?
2) If in the future I wanna heat up the pool during the cold season (Mid October to mid-April), I am in Gainesville Florida. Is it the same cost to build a system that heats up the spa and (optionally) heats up the pool, or is it cheaper to just heat up the spa? I am not planning to heat the pool all winter but maybe only for special events.
3) Which material were you suggesting for my case? I see some people do fiberglass, others gunite, others shotcrete. Pros and cons of these materials?
4) I emailed a pool contractor, he said it is gonna cost ~55k or more to add the spa and gas line. That is for a 6’ x 8’ or 7’ x 7’ spa in Concrete (but shotcrete not gunite). When I asked how come so expensive, he said: "Per my engineer – I must cut into the shell of the pool quite a bit to tie the pool and spa together which then requires the pool to be replastered and tiled. We even tried using a trough on one of our jobs and if I recall they still wanted us to cut 9” into the pool beam." Do you think 55k is a fair ballpark price?
5) I am reading online that gas is the best option for North Florida, do you agree? Heat pump would be too slow, right? How slower than gas? And pricewise?
6) Would you suggest the spa should be at the same level or higher level than the pool? I feel that a higher level allows you to have a nice waterfall with lighting effects, but shouldn't it cost more to build higher? Or actualy cheaper cause you need to dig shallower hole? But more cost to pump water in the spa if it has a higher level? It would be good to have an estimate of the extra cost per year for a pool 1 foot above the ground, but i guess it is negligible. It would be also relatively harder to enter since you need to step over.
Thank you
Best
Venexiano
Thank you
Best
Venexiano
