I ran home at lunch and re-tested. Pool is in full sun from around 7:45am to 3:00pm.
FC 15 (that is where it was this morning, I posted 13 by mistake. 15 is my shock level.)
CC 0
PH 8.0
I will go ahead and re-do the OCLT as advised. I probably won't have to add much chlorine, if at all, to get back to shock level before tonight anyway.
So should I add the salt, wait for the FC level to fall below 10ppm and then adjust the TA and PH and then add the borates? Plug the SWG back in at 5ppm and adjust it stay between 3-5ppm. Shoudn't I raise the CYA back up also. Per pool school 70-80ppm for plaster w/SWG. When should I adjust that?
Thanks for all the help. This has been fun. Sounds crazy but, my pool is looking great and I have only spent $11.00 on chlorine plus the test kit. It is so good doing your own test and knowing the real numbers.
CC 0
PH 8.0
