I've had this pool for seven years now. My frequency of vacuuming seems to continuously go up. Last year I thought I had an algae issue so I shocked it. Still had the problem. Shocked again and left it shocked for quite a while despite otherwise clear water and no overnight drop.... Same problem.
This year, same thing. I can vacuum one night come home the next night and vacuum and there is a clear and significant later if something on the bottom of the pool. Over the last weekend I vacuumed twice a day. Friday night, Saturday morning, Saturday night. By Sunday morning nothing on the bottom, clear water but I continued anyway. Come home Monday night.... Have to vacuum.
I run the pump 3 to 4 hours a day everyday. Filter seems to be working as if I vacuum twice a day it captures everything.
I am in the process of running lower PH because the bottom of the pool got a build up on it and was rough. That was not the case last year though.
All the other Numbers seem to be fine.
We do have a lot of trees around but this is not debris but a greenish layer of stuff that clearly looks like algae that just settles out.
Any idea what I should be looking at.... Really tired of vacuuming.
Thank you.
Thank you.
