- Jan 30, 2013
- 10
- Plaster
- Pentair Intellichlor IC-40
Trying to design my pool lay out at the moment.
The inground pool will have one end with benches and spa jet returns within the pool itself.
Our plumber suggests using a separate pump for this but I cannot see the need since we can just redirect the pool returns with a 3-way valve when we want a spa effect.
All the lines will be 2 inch fed by two in ground drains and two skimmers. The pump is an Intellipro 3. I am assuming there will be a 2 hp blower and the return flow will be directed through the Clean and clear 420.
How many jets can I have on a system like this before we start to lose pressure?
Is there a better layout for what we want to achieve.
Based in Costa Rica so no need for a heater,
