That makes sense about the skimmer basket. What happens if you have the valve turned off right after the skimmer and you need to work on the pump basket, like to remove the debris and you don't turn off the pump?
Also, debating I should use unions in the installation. I will be going right into the ground from the return and skimmer, over about 15 feet to the equipment.
