- Apr 29, 2023
- 11
- Plaster
- Pentair Intellichlor IC-40
It appears that a common leak problem with these hot tubs in the drain line in the cavity of the Moto-massage unit. Apparently inferior plastic and hose tension cause the plastic nipple that the hose slides onto to break. (see picture). Easy to get to if you jack up hot tub and cut a 6 inch by 6 inch hole in the foam. I fixed mine by simply putting self threaded screw in both the hose and the broken nipple hole into the cavity with some epoxy for added insurance. Figured if I ever need to drain/winterize the spa I will just suck the water out with a siphon. My model is a jetsetter but several models have this massage unit.
