First time posting on any type of pool forum I’m not sure if I’m posting in the right spot phosphates are food for algae so this forum probably was the best spot for my question It’s actually the first time I had really High phosphate levels.
My pool 18 round
Hayward EC40 1hp pump
I use a frog system
So I opened up my pool on Sunday as usual my water was crystal clear it always is when I open it I have a very good cover
I usually drop a gallon of liquid bleach in when I open my pool this year I did something different and put a bag of green out in
There was a few leaves in the pool nothing crazy I planned on vacuuming it last night but it started raining last night so I planned on vacuuming tonight
Maybe I should not have tested my water today after some heavy rain at times last night but I did get it tested today at Leslie’s
As expected my ph was a touch low with the rain 6.8
Slightly acidic about 150
Chlorine 4.5
My phosphates were off the chart at 2000ppm
I’ve never had phosphates so high not sure why it’s so high?could it have been a combination of the rain and few stray leaves I usually vacuum immediately after opening my pool but with the rain last night it got pushed to today
Of course Leslie’s immediately tried to sell me chemical’s to bring my phosphates down I know phosphates are food for algae but my water is so crystal clear like glass it always is when I open my pool with the cover I have!.
My question being are the phosphates being this High something I need to worry about.someone suggested vacuuming then draining about 8-10” of water then replacing with fresh water
I’ve read phosphates don’t go away on their own but I really don’t want to add any unnecessary chemicals to my pool with my water looking so clear
I’ve never dealt with high phosphate’s before so I’m kind of scratching my head on how did they get so high the only thing I did differently this year than the past few years was use Green out and have a heavy rainfall almost immediately after opening my pool I can’t see the green out contributing to the high phosphate’s.but that’s literally the only thing I did different adding the green out vs bleach!
I always connected high phosphate to algae but my water is so clear right now
Is the high phosphate level something I need to be concerned about?
I vacuumed the pool tonight honestly there was not a whole lot to vacuum it was fairly clean so I’m not quite sure what spiked my phosphates I did wait a little bit longer to open my pool I usually open it right before Memorial Day but it’s been cool up here in Newyork so I did not want to open the pool and start running the filter unnecessarily spinning my electric meter as it usually does when I start running the filter if it was still too cool to use the pool!
I’m kind of miffed right now hoping it drops on its own probably unlikely but hoping!
Thank-you
My pool 18 round
I use a frog system
Chlorine 4.5
Thank-you
