Thanks I’ll get reading! We go between France and UK, so cover pool when not here and winterise in November. I am searching for thé recommended test kits, don’t think they’re available here in France or UK. Will keep trying. I have 7 in 1 strips atm. We sanitise with chlorine multi-function tablets and chlorine shock tablets when required. Have struggled to balance ph and alkalinity levels lately and lost faith in the more simple test strips hence bought the 7 in 1!It appears that you have algae.
I see that you are in France, are you able to get either the TF-100 or Taylor K-2006 test kit?
With one of these kits, you can run accurate testing to evaluate the water chemistry.
How do you sanitize your pool in France?
Please create a signature, this will provide us with information that will allow us to help you.
Create Your Signature - Further Reading
www.troublefreepool.com
Algae forms when the chlorine levels in your pool are too low, the bad news is that it takes much more work and chlorine to kill an algae bloom than it takes to prevent one. The good news is that you have found TFP and we can help you.
Here is a link to pool school's section on algae:
Algae Archives
Here is a link to begin your education on maintaining a sparkly clear water:
Pool Care Basics Archives
Your one-stop shop for all things TFP to include: ABCs of Water Chemistry, Recommended Chemicals/Levels, Test Kits, Troubleshooting, and much more!www.troublefreepool.com
Thank you for this detailed information. My brand new 7 in 1 strips (all I have at the moment) are showing the CYA as quite low (about 20-30ppm) and the free chlorine as 3 ppm (though my liquid test kit (simple version) is showing way higher in mg/l.) Total chlorine was at 9 ppm on the strip. Ph is 7.8 ish on strip and 7.7 on liquid test.The tablets most likely are trichlor - for every 2 ppm of fc (free chlorine) you get from them you also add 1ppm of cya. Dichlor is even worse- it’s a 1:1 increase.
The fc gets used up daily but the cya remains until you exchange water & builds to an unmanageable level.
This makes it harder & harder to maintain the necessary fc level required for daily sanitation & things go south.
If your cya is quite high it’s best to exchange water to lower the cya level before attempting the SLAM Process as it’s impractical to attempt to maintain such high fc levels.
Here’s some information on obtaining adequate test kits outside the US- some have had luck on amazon.
Dichlor & Trichlor are also quite acidic so they lower ph & can crash ta in short order. We recommend liquid chlorine for this reason.Pool Test Kits - Further Reading
Until you get drop based kit to get more accurate data you can add 5ppm worth of liquid chlorine/unadulterated bleach (no splashless/cloromax/fabric conditioners) each day to keep things from getting worse. Pour it slowly infront of a running return & brush the area.
Use PoolMath to calculate amounts.
I live in france and managed to buy the Taylor K-2006 kit from a spanish pool shop - reasonable price of 169 euros.Thanks I’ll get reading! We go between France and UK, so cover pool when not here and winterise in November. I am searching for thé recommended test kits, don’t think they’re available here in France or UK. Will keep trying. I have 7 in 1 strips atm. We sanitise with chlorine multi-function tablets and chlorine shock tablets when required. Have struggled to balance ph and alkalinity levels lately and lost faith in the more simple test strips hence bought the 7 in 1!
Hi PjinFrance!I live in france and managed to buy the Taylor K-2006 kit from a spanish pool shop - reasonable price of 169 euros.
Taylor K-2006 multiparametric analyzer test kit
• High precision test.• Chlorine determination by DPD-FAS method• Determines up to 8 water parameters.• High quality reagents.• Supplied in a plastic case.piscinasyproductos.es
Thank you! Good to have fellow pool owners in France.My immediate issue is not having enough time to order and do any chemistry adjustments before we head back to UK next Wed. . Whether it is ok to leave the sorry, toxic mess or try to dilute it at least. I must look into restrictions as I have already ‘topped-up’ twice this summer. SAUR will be on to me!!In France, you can get these two kits on Amazon. Together, they are the equivalent of the Taylor K-2006.
Fas-DPD test
Taylor K-2005
Hi again,With the testing methods at your disposal, unfortunately test strips are extremely inaccurate, unless you can get a test kit we won't know exactly what you need to correct your water chemistry.
We also don't believe pool store testing, but I believe that they are on the right trail, your CYA is probably high due to the use of chlorine tablets, which increase the CYA along with the chlorine. The tablets dissolve and put chlorine and CYA in the pool, the chlorine breaks down as it fights biologicals and UV, but the CYA stays and builds up. It doesn't take long to have too much CYA for the chlorine level, and you get an algae bloom.
Without proper testing it's difficult to say if you are slightly out of CYA/chlorine balance or if your CYA is sky high.
I can tell you this, you would be better serviced if you stopped the tablets and switched to sodium hypochlorite, (bleach, plain bleach, no scents and not a splash free bleach). Sodium hypochlorite, chlorine gas and salt water chlorine generators are the only three ways to add chlorine to your pool without also adding CYA or calcium. In the US, sodium hypochlorite can be purchased at pool stores, hardware stores, grocery stores, some farm stores and some department stores, I can't tell you where you might find it in France. Chlorine gas is not readily available to home owners in the US due to the toxicity. A Salt Water Chlorine Generators is my preferred method to sanitize the pool, but at least in the US, there is significant up front cost associated with SWG.
A SLAM is the best way to rid your pool of algae, but without a good supply of sodium hypochlorite , and a proper test kit, you would be operating in the dark, never knowing if you have too much CYA for the chlorine level. Dumping large amounts of sodium hypochlorite, without proper testing may eventually wipe out the algae, but dump and pray is not a good strategy, you could cause damage to the pool and equipment if chlorine levels get too high, and you would never know what your target levels should be, again dump and pray is not recommended.
SLAM - Shock Level and Maintain
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.www.troublefreepool.com
Algae is always caused when chlorine levels are too low for the CYA in the pool, CYA management and chlorine levels are the key to preventing algae. You always want to maintain your chlorine levels at 7.5% to 10% of your CYA level. So if your CYA level is 50ppm, then 7.5% would be 3.75ppm free chlorine & 10% would be 5ppm free chlorine.
Thank you for your advice. By liquid chlorine do you mean regular bleach? Also could you please say how much liquid chlorine per 10m3 ? I’m not understanding ppm. Thanks in advance!I think the best you can do is add 5ppm of liquid chlorine, PER DAY, while you are gone to keep the algae at bay and deal with it when you come back.
It is 30m3 which I think equates to 30,000l or 8000gal.Yes, regular bleach. Pool liquid chlorine if you can get it. I think we have some translation error...do you mean 10,000 square meters? 10m3 is 107 gallons. What is the total volume of the pool please and I will give you quantity.
Thank you very much for the trouble you are taking. This is very informative.83 ounces of 6% Bleach will add 5ppm. So add 83 ounces will add 5ppm to your pool.
10% Liquid chlorine would take 50 ounces.
12.5% would take 40 ounces.
This addition should be made daily.
