I need to get my own build thread going but I had no such luck getting everything stabilized with the braces and stakes. My site is all sand with a trace to no silt. I could push the stakes in by hand. The concrete collar locked it up pretty good though. Of course, the walls got pushed by the concrete because all of the stakes were worthless. I had to shovel out a few areas once the concrete began to set, shift the walls back, then shovel the concrete back into place and tamp it down. So much fun. Especially after having just shoveled it half way around the pool in the first place. I also had the joy of a blowout along one side of the hopper where a nice concrete flow had to be shoveled out. I'm back on track now and looking to be swimming by the weekend but I hope your soil is more cooperative!
By the way, on your walkout basement project, did you check to see how deep the footing was along that wall? If it is above frost depth and you have clay soils you could have a problem with heaving in the winter. You can put foam insulation board under the sidewalk extending out 3 or 4 feet to provide protection if it might be an issue.
