My pump died on May 29th, and I replaced it with a Pentair IntelliFlo variable speed unit. Due to some issues, I couldn't get it up and running until yesterday. I expected my pool to look like a swamp, but surprisingly, it is still crystal clear. I'm very new to variable speed pumps, and I'm not sure how I should proceed. Should I be starting with a SLAM? Would I run the pump at low RPM, or should I be running it higher until the water is properly chlorinated? All of my values are within the correct range (verified with K-2005 test kit) other than I have no chlorine in the water. I didn't turn the SWG on yet, as I wasn't sure if I will need to superchlorinate first.
