Paula,
The floc is a bandaid at best- it only helps you mechanically remove dead algae. It does nothing to kill it or prevent it from growing again in short order. Unless you use the correct amount of chlorine it continues to proliferate.
To truly rid your pool of the algae you need to do the
SLAM Process with liquid chlorine. This involves knowing your true cya level (which may be very different than the strip says) & maintaining the proper shock/slam fc level for that
FC/CYA Levels until you pass all 3 end of slam criteria.
To do this you need to be able to accurately test your water frequently with your own proper test kit.
A Taylor k2006c or tf100/pro are the only ones recommended because of the specific tests they contain. Others are all missing something.
Test Kits Compared
Unfortunately “guess” strips just don’t cut the mustard with their ranges & varying results. They are also easily bleached out at elevated fc levels.
Until your kit comes add nothing but 5ppm worth of liquid chlorine to the pool each day to prevent things from getting worse (pour it slowly infront of a running return & brush the area).
Use
PoolMath to calculate amounts.
If your pool has been off for 48 hours & the floc hasn’t settled it’s probably not going to but the algae is still proliferating with no chlorine.
You can either proceed with the slam process now (knowing you will at least need to deep clean the filter or possibly replace the sand again soon) or you can drain the pool/exchange the water & start fresh with a quick
SLAM Process once refilled.
Is this a permanent above ground pool or a temporary intex style pool?
What size/brand is the sand filter?
