I believe the "nut" portion of the union kit is still on the pump housing. She needs to lefty lucy that piece off. That's the point I, apparently, haven't been able to convey.
-Matt
All of that information has been posted. you can't "lefty loosen it. It isn't threaded. Unless your talking about the nut that I am posting a picture of here. I just took it off. Of course I know how to clean my filters. They were not dirty. However, they have not been cleaned as often as I wanted them cleaned, due to my boyfriend that never does anything. Huh, gonna half to look. I see why all of this is so disjointed everyone. First, here is a picture of the nut and I can clearly see why and how it blew.
It melted. Now the thing is, I don't know if it was this way before as well or if it got too hot when this happened and that is what melted it... There was a ton of silicon on it. As for the comment about the threaded pipe and using nipple threaded 80. That came from the pool guy who wants to come and charge me $125 to do the job. What is said here about that not being needed because of the pressure etc. makes good sense. Why than would he want to do that? I explained to him that it wasn't threaded...??? That is what threw me off and why I have spent forever trying to find the right parts to manufacture the opening on the pump housing into a threaded. Now, logically thinking, obviously it is tight enough without that or the silicon alone wouldn't have held it... And, on that same note, I don't image that the union, and nut are made out of Schedule 40. They must be tougher than that. I can pretty much guarantee that the people that lost this house never once put any magic lube on any parts nor did they probably ever clean out the skimmer basket. They didn't even clean the shower here once I don't think! They were not really bright. This is my first pool. I research everything on the internet to learn how to do things. I am somewhat mechanically inclined. I repaired my washing machine by myself, using parts that I made and it has been working fine for two years since... And, I did install a garbage disposal last week :queen:... and also what about this here on this site
"Schedule 40 plumbing is fine most places on a residential pool, but threaded into the pump directly it will almost always leak over time. We recommend that if you need to thread directly into the pump that you install a schedule 80 nipple and then transition to your regular plumbing. "..
http://www.aqua-man.com/techdisplay.asp?Ic=T2 When the problem started, my neighbor put a ton of silicon on it and we let it sit for 24 hours. You will really get a laugh out of this. Now be nice, I am going to post the picture of what I did when it didn't seal up right away.
I thought I was so smart.... DUH!!!!
View attachment 43723 Should there not have been a tone of silicon put on? I know that I shouldn't have used the things above to try and tighten it but heck, I thought I was being good and handy. I am a girl you all know!!!
What I didn't understand in the beginning was why it started to leak 8 weeks ago. I wasn't sure if the pipe that goes into the pump housing was suppose to be glued and my BF just left something out or what. I had a bunch of o-rings around and put a new one in. The reason I had a bunch around is because when my boyfriend puts things back together he leaves things out!
As for the question of why it didn't run all the water out and ruin my motor, posted already but, I was out there at 4:30 am letting the dog out. At 5:30 the cat wanted out. I went to see if the pump was running because it hadn't been at 4:30 and I thought I had set the time to start some time around then. Well, at 5:30 I found the problem and quickly shut it off. In looking at the piece of the kit that is still on there it is intact. Why then do I need as was said here,
"You need 1 of those kits, a piece of PVC pipe from Lowes, a coupler, and some pvc cement."? Can't the new nut go on the existing bolt that is glued to my piping? Am I being dumb? See this picture, that is how it was and still is...
One more answer, in regards to this,
"The correct pipe size coming out of that pump is 2". I don't know how/why/when the subject of 3" came up. Everyone keeps telling me I have to get a piece of PVC pipe, a couple, etc... well my pipes are different sizes so I need to figure out where to connect what things at and what sizes to buy depending on that. Oh, one more thing to clear up, here
happyheaven says, (Disclaimer: The OP has pics of piping which I cannot identify. I do not, for instance, know what the three lines branching from the filter's outlet are - but it looks like 1/2 of the large-diameter pipes have valves turned to 'closed' - the only one open is the one that cannot be closed, so it may be entirely safe for that valve to be closed.) From the filter is the one with the valve closed, that is to drain water. the other goes from the top of the pump housing to the filter and the third is from the suction side of the pump....
I hope that clears things up. So, all I am waiting on is, why do I still need to add and cut and glue PVC pipe???
And lastly, thank you all so much for spending your time reading through this and trying to decipher what was going on, and what needs to be done. I can't tell you all how much I appreciate it... :handshake:
:grin:
