- Oct 31, 2021
- 22
- Plaster
- Jandy Aquapure 1400
Hi Experts,
I have a Aqualink PDA PS8 that controls my pool pump and other equipment, and it was programmed to run every day from 8:30am to 7:00 pm. However, recently it seems have some issues and what observed made me very confused.
Earlier this week, I noticed that my pool would started running before the programed start time and the date and time was reset to 2009. After manually correcting the time with the remote it could continue to run until 7pm, but the next day, it would reset again in the morning. First I thought is the 9v battery, even though we did not have any power outage or tripped breaker. I replaced a new battery, but that did NOT resolve the issue.
Below is what I observed so far after paying close attention to it for a few days.
Any suggestion on how to troubleshoot is much appreciated!!
Thank you!
- When it starts running during the day, everything is fine, the clock is accurate and it stops at the programed time.
- I am not clear when the resetting happens(seems random to me). I am sure it only happens during the "sleep" status.
- Last night, I finally captured once when it reset. I noticed the "Auto" light was off and the "SPA Mode" light is on, but the pools pump is not running. None of the button would work, tried the reset button, not working. I cut off the power from the breaker panel, waited 1-2 minutes and turn it on, still the same, no button works and the SPA Mode light keep on. Below is the picture when it happens. I also tried disconnect the battery and cut off the power, it does not help. This morning around 10am, the pool starts running again, all the light and button seems working again, except the time was reset to 2009.
- I checked the wires and did not find any lose wire or broken wire. Below are some pictures of what looked inside. The only thing I can think of is these two weeks are every hot here with outside temp 110+ F
Thank you!
