Yes, it takes time. Sand can get clumped together overtime especially if any potions like clarifiers have been used in the past.
You can do a deep clean of the sand to ensure it’s good to go & also inspect the sand level at the same time. You should deep clean the sand every couple years as maintenance anyway.
Here’s the how to
This post will walk you through the anatomy of a sand filter, and then provide a video at the end for how to deep clean your sand filter. The filter used in the photos and videos is a Hayward S180T top mount sand filter. The images are of a similar filter. Obviously not all filters are...
www.google.com
After confirming your sand is good to go you can add a little de to help capture the finer particles. Be sure you’re home to babysit the filter as the pressure can rise quickly.
A clean pool filter will increase the efficiency of your pool! ... your filter are to backwash it, clean the manifolds and grids, and add new DE.
www.google.com
Check the foam in the weir door (take it out and look at both sides)
No ladder or steps?
Correct
