Toggkes between heating to service system to eventually service heater. Does that several times before shutting down.
Service System indicates a flow problem.Toggles between heating to service system to eventually service heater. Does that several times before shutting down.
That is way too low and it does not correspond to the AGS.Was F. Removed thermostat and now shuts off around 231 F
What error codes are showing up?Yes it shuts down at 101c.
Don't do that.I just taped the gas valve with a hammer and now it doesn't fire up.
101 C is 213.8 F.Yes it shuts down at 101c.
The heater is 10 years old. I have replaced bypass valve and thermal regulator.The heater has an internal water flow problem causing it to overheat and trigger the AGS.
It may be a scaled heat exchanger, thermal regulator, or bypass valve.
How old is the heater?
Do you have pics of what the external and internals of the heater?
The heater is 10 years old. I have replaced bypass valve and thermal regulator. The unit turns off when exhaust temp hits about 238.
yes. It's seems to consistently shut down when exhaust temp is in 230's. Also runs very smooth no knocking or odd noises. However it does switch from service system a few times and then goes to service heater right before shutting off.Can you show pictures of everything?
