- Mar 20, 2023
- 228
- Vinyl
- CircuPool Universal40
Hey all-
Bought this house in December with the pool. I've been working on learning all about it and getting things set up and ready. I read the deep cleaning procedure and decided to do that. I had ordered a gasket kit on Amazon and thought I was all prepped and ready. Undid all 24 bolts and popped the top half off and got to work. I did decide to weigh out 100 lbs of sand and replace with new, because it was real dirty, taking forever to clear up, and had the bags of fresh filter sand at the house anyway.
I put it back together with the new giant o-ring, which I lubed with the Jack's Multilube. After bolting everything together, I had a pretty good leak. Tried again the next day, thinking maybe it had shifted or otherwise got wonky. Also tried to do a bit better of a star pattern with the bolting. Still leaked.
So I went to the pool store and bought an OEM giant o-ring, and even got a fresh set of bolts. I'd also watched a YouTube video where the guy said that using the lube is a common cause of leaks. And tonight tried again. I'd printed out a diagram of a star pattern, and even numbered each bolt hole on the top half accordingly, so I would easily do the correct bolting pattern without having to go back and forth to the diagram and count bolts and all that.
I was confident that I'd be able to make a post stating it I got it all figured out, and even though I didn't know what the fix was (removing all the grease, using an OEM gasket, or triple-checking that I had the right star pattern) I'd finally gotten it.
But when I fired up the pump after all that...
IT NOW LEAKS MORE THAN THE FIRST TWO TRIES!
I did see one comment where someone said that adding DE actually seemed to help. I suppose the tiny particles just plugged up the leak. So I followed the procedure as described, noted the amount needed to raise the PSI about 1 PSI for future reference, and then added a little more for this time, figuring I'll just end up flushing that bit out next time I backwash the filter and maybe need to do it a little sooner.
Anyone have any sort of advice of where to go from here? It did not leak before I started all this. My wife suggested I call the pool store and have someone out; I told her they would probably just try to sell me a new filter.
It's even more annoying because the pump and filter are set up under our deck, so to do all this, I have to be crouched over the whole time.
