Hayward Pool Filter VSP Comm Error
Alexander M Benning
4
Mount Pleasant SC
We had someone working on our pool yesterday. Saturday a big storm knocked out our pool filter breaker. When they left it worked great. Next day we had about 50 “Check System” alerts saying filter VSP Comm error. Can anyone help out?
Date Posted: April 14 2024
Hey Alex and Welcome !!!!
What equipment do you have ? (Make and model #s are relevant)
Got pics of the panels and equipment pad ?
Welcome to TFP.
What model Omni system?
What model VS pump?
Hayward has seen some instances where the HUA from a Gen 3 VS pump was not visible to the Omni control.
These instances have occurred after:
  • A power brownout
  • The pump was installed with incorrect dipswitch position and the dipswitch was moved while power to the pump was still on.
Once Power was restored, or the pump powered down and back up the HUA would not populate into the control.
Solution that Hayward found is that power needs to be turned off to the pump for a MINIMUM of 5 minutes and as much as 15 minutes to allow the drive to reset. Once power is restored the HUA was visible to the Omni and the pump worked normally.
Here are some of the photos check next thread for the rest
Here are the rest of the photos. See reference below.
Amount of water in gallons: 15,500 gallons
Mouth and Year built: February 2015
