High Amp Shutdown with High Water Temperatures
The Aquarite has a design flaw where the high amp shutdown will happen at normal salinity when the water temperature is above about 90 degrees.[44]
AquaRite, ProLogic, and AquaPlus all shut down at 8.0 amps. Some software revisions shut down at 10 amps, but we are not sure which revisions use 10 vs. 8. Most software revisions shut down at 8.0 amps.[45]
At "normal" salinity levels of 3,200 ppm, the amperage begins to approach or exceed 8.0 amps at about 92 degrees.
This can be a problem for warmer pools, especially when the cell is downstream from a gas heater where the temperature exiting the heater can be up to 16.8 degrees Fahrenheit higher than the inlet temperature.
To stay below the 8.0 amp limit, you have to maintain the salinity below about 2,800 ppm. The system will work down to 2,400 ppm, but it will give a constant "Low Salinity" warning at 2,700 ppm. Trying to keep the salinity exactly at 2,800 to avoid getting a low salinity warning or a high amp error is difficult.
To avoid the low salinity warning and the high amp shutdown, you can change a T-15 the cell type to T-9. This will make the salinity read higher than actual so that you can operate at an actual salinity of 2,400 to 2,800 ppm without the low salinity warning all the time.
You would try to keep the amperage between about 6 to 7 amps maximum.
You would make sure that the amperage was always below 8.0, even when the heater was on.
www.troublefreepool.com
https://www.troublefreepool.com/wik...igh_Amp_Shutdown_with_High_Water_Temperatures
