Hi all have the gva-23 see below which is leaking can you point me in the direction of the valve kit and how to thanks
Hi James can you assist in my issue with the pictures of a leaking value actuator
See post #3.Thanks guys can you link me the parts needdd to fix thanks
Is the equipment below water level? If not, you will only lose what is in the filter and maybe a little from the pump. Any O ring kit that will fit a 3-way valve will work on your 3-way valve, Jandy, Pentair, Hayward, CMP, etc. They all use the same O rings.My next question is there any issue replacing this seal kit and not loosing any water thanks all
Silicone grease is a good idea. The gold standard is Aladdin Magic Lube II. Seems pricey, but one tube will do many, many o-rings and gaskets. A thin coating is enough. This includes your filter seal whenever you open it. Some here say it's not a bad idea to replace o-rings every few years and lube the diverter seal inside the valves.... do I need plumber grease also and the one posted above has large o ring and 2 small is there torque settings for the reinstalling thanks?
A pool lube is preferable. DO NOT use a petroleum product like Vaseline. Any O ring set for a 2 or 3-way valve will work, they are all the same, regardless of brand.Thanks poolman makes sense, can I use any plumber grease or is it special and can you see the above link and confirm if they will work .
The pool is below in height of the pool gear by 1ft
Is there a how to guide
