Ok so by this evening my water level should be back up to turn the pump and filter back on..... I dragged the bottom around and as far as I could reach towards the middle and now hardly getting any chunky debris but the water def gets darker from the dirt that gets stirred up. I then took the brush and brushed along the edges and as far out to the middle as I could reach to try and loosing up anything that is still on the bottom.
I've added all 10 gal of bleach now, last was added around 530 am. I thought I'd try and learn this whole water testing thing and not sure if I did it right.....
FC=was really orange, not any type of yellow
PH= was pinkish and looked to be about 7.5
TA= took 30 drops to change from green to red (300?)
CH= took 35 drops to change form red to blue (350?)
CYA= said to look down into tube and add the mixture until I couldnt see the black dot, but it was filled and never got cloudy......
I did pick up a few more gal of bleach in case it needs more and also pick up some borax and baking soda cause from what I've read that members have suggested that would be the BBB way......... but the color has def changed from the nasty green with chunks of algae floating to a cloudy blueish/clear...... can almost see the bottom if I place the net now there you can see the blue net but it's still really cloudy but once the water level is up to start circulating
L
L
