Thanks for confirming, Jesse. I'll test the water out again and ensure the level is to 10 throughout the evening, and write back in the morning!
The stabilizer will take a few days to dissolve. Add it ASAP.Ok we just retested the water and the free chlorine is now showing around 2 or 3. Seems like an awfully fast drop, no? We just added an additional 242 oz of bleach to raise it. I'll wait a bit and reconfirm the value hits 10 and add the stabilizer then (or should I add that now?)
That is incorrect.Through research on this forum, I'm finding there seems to be a split down the middle as to whether or not I need to use the sock method. If I dissolve and dump into the skimmer, since I have the filter running 24/7 right now, will that be a bad thing?
Your worst fear nailed it. It's pretty common that a minute or so after the FAS-DPD test goes clear that it turns back to pink. You count the first time it went clear as the FC....
I just also did a retest of the free chlorine but seems that the number is maybe only running around 7. I know I'm supposed to keep it to a 10, but here's my question: when I do the free chlorine test, when i added the first 5 drops or so, it went to clear. A minute or two it showed up slightly pink again, I add more, etc. and this went on for about 15 minutes. I eventually got to 14 drops before no pink tinge snuck back in. Does that seem to be a valid test if that's happening? If it's not, and I count only the first time it goes to clear that means the chlorine is only around a 2.5 - and that's after adding 484 of 8.25% bleach today!
I have seriously got to find a store that carries more bleach than the grocery store does.
Lorraine
Durachlor is dichlor. It adds CYA to the water. That will mean you will need to account for it and raise the SLAM level and the maintenance FC levels. Here's the MSDS for it. It will just cloud things - that pun was intentional, I meant confuse, not actually cloud the pool - so I would refrain from using that. Later on, when the pool is sparkling, if you want to raise CYA, it will be good for that.Richard -
I have about a half of tub of granulated Durachlor left from last pool season (July timeframe) so I could use the remainder of it to boost the chlorine levels tonight. Is that an okay option or do I want to pretend like this isn't sitting in my garage and wait for the stores to open tomorrow?
Lorraine
