You can do the diluted test to test above 100, Pool School - Extended Test Kit Directions
About 60% seems good to me.
Thank you!
I will try, I have not done that before. I can't find the directions, will you please share the link with directions. Thank youGood point, Pooldv! Thought someone had already mentioned the diluted CYA test!
Isipwater, you can still do that test as the CYA won't change until you start to refill.
Couple more questions. I have the pump on during the fill, is that alright?Test CYA as soon as it is full and circulates for a couple hours.
Thanks, what does primed meanIt is fine to have your pump on as long as it is primed. Ok to add bleach up to shock level for your projected cya, [FC/CYA][/FC/CYA].
