Hello all! I have had to replace either the start and run capacitor nearly every year. The pump started running on high only when I decided to close it this spring. I just filled the tub and confirmed that it was still only running on high. While letting it run for a while to add some pipe cleaner the GFCI tripped. I checked the run capacitor and found it to be bulged out at the end and disformed. I replaced it. Now the GFCI trips instantly. I have removed all connections and it still trips. This disconnect box was put in less than a year ago. Any reason why the capacitor would become bulged out at the top. Is the GFCI damaged and unrelated to the capacitor issue? The motor is well past replacement age but I am holding out to replace the entire tub. Thoughts? Thanks in advance.
