Howdy all -
I have a used 20-yr old Sundance Marin 850 that was installed over four years ago and runs normally - until last week.
Symptoms:
1. The dreaded "Flashing FLO" error.
2. The pumps all run.
3. I could feel heat coming from the area below the control panel.
4. It won't heat past the low 80F range.
What I've tried:
A. Replaced the Stage 2 filter. Didn't fix it.
B. Removed and sprayed off the Stage 1 (pleated filter). Made sure I didn't have air bubbles. Even ran the hose into either side of the filter opening. Didn't fix it either.
C. Ordered a Flow Switch and installed it tonight.
D. When that didn't fix it, I tried running the pumps for a couple minutes without the filter. Still no luck.
My Questions:
I. One thing puzzles me about the pic - even the old Flow Switch housing didn't have water full to the top. Is that indicative of a weak circ pump?
II. Before I order a circ pump and find out that's not really the problem...can anyone tell me how to conclusively diagnose it?
III. Or, is there one last-ditch thing I should try (that I haven't done already - see "What I've tried")?
Thank you!
Symptoms:
What I've tried:
My Questions:
Thank you!
