How often should I check the CYA levels after slam?Add half the amount of DE you were adding. See if that lengthens the time to backwash.
Thanks.![]()
Basic Pool Care Schedule
This basic pool care schedule can guide you in creating your own pool care routine. Regular pool maintenance will keep your water sparkling!www.troublefreepool.com
Did you rinse the bottle well ?Used up the whole bottle and still see the black dot.
Granular.Did you rinse the bottle well ?
(Sorry, 16 pages later I forget if we went over the downfalls of liquid CYA)
The LOL is on me. I misread you 'used the whole bottle' as a bottle of new CYA, not the sample mix squirter thingie.Granular.. Sock method lol
Yeah, I totally forgot about the CYA and I checked my chlorine level after adding yesterday and it was going down so fast. It made no sense because the pool is almost clear. Then I realized my CYA is probably at 10 or even less from backwashing. Anyway. Last time I’m ever letting my pool get this bad lol what a nightmare it was when I opened it to see a dark green sludge. New pool owner lesson learned!The LOL is on me. I misread you 'used the whole bottle' as a bottle of new CYA, not the sample mix squirter thingie.
You should add 10 ppm CYA and hopefully be back at 30 for whatever SLAM is left.
There are 2 HUGE benefits of a SLAM. The newb gets a crash course in poolcare and testing/adjusting is a snap down the road, and 2, they never EVER want to do it again.Anyway. Last time I’m ever letting my pool get this bad
