- Aug 20, 2020
- 6,292
- Plaster
- CircuPool RJ-60
Here’s what a gizmo is.@Bperry
What is a skimmer guard? I’m just a little more confused now. I would rather leave the pool all the way to the top because then I don’t have to remove the hoses. Is that right? And then I just put antifreeze in the motor? And just circulate it. Well, I don’t want it to go into the pool though, oh my
They also make a skimmer faceplate thing that blocks off the whole skimmer so it can be drained. Anything that can be drained completely doesn’t even need antifreeze.
You can’t just plug stuff and not drain the water. The water has to be drained out of the pump and the hoses.
Honestly, you have an above ground pool. Easiest thing is to drain it below the skimmer, remove those hoses, and plug the returns.
