Your FC level is very low...I am assuming you should still be shocking? I would test FC every hour (if you can or at least as often as weather/schedule allows) and use those results to add chlorine per the poolcalculator to keep your levels up. That is the most important thing to do now. Do not worry about TA, CH etc. until you get through the shocking process. Your ph is high and should be brought down with Muratic Acid.
I also don't think you have added enough CYA for your pool...I see you have only added 36 ounces (was that dry CYA) which the poolcalculator gives me ~15 ppm? I am showing you need ~70 ounces by volume of stabilizer total to get from 0 to 30 ppm CYA.
