Opened the pool a few days back. There was a hole in the liner, leaving only about 20" of water at opening. I have filled to the top. Below are my initial readings. I know adding all the new water is the reason the CYA is so low. 10ish is a guess as I had to fill the tube all the way to the top...and I could still see the black dot. I was going to tackle that first, but I wasn't sure if I should adjust the PH down to 7.2 first? Also, do I need to be concerned with the high TA value? I don't think I ever was able to drop it below 200 all of last summer.
Thanks
FC: 0
TC: 0
PH: 7.5
TA: 240
CH: 350
CYA: 10ish
Thanks
FC: 0
TC: 0
PH: 7.5
TA: 240
CH: 350
CYA: 10ish
