Hi - I am doing my first SLAM since following the TFP method. Long Story short...a lot of rain and me miscalculating chlorine consumption under my mesh cover this year led to an opening algae bloom. A flock of birdz landing in what they though was a pond probably didn't help....
I started out by putting 2-gallons of 12.5% which was about what pool math said I needed to get to SLAM level of 16. After 6-hours FC only measured 7 with CC1.0, so I put in another Gallon. Following morning I was up to FC 11, CC .5. Since then the pool seems to be consuming a full gallon of FC every 8-12 hours as the highest result I have gotten is FC 11.5. The green cloudiness is gone and now it is just cloudy. I have vacuumed twice with skimmer sock, and been brushing walls and crevaces.
Questions:.
1. Should I be testing 1-2 hours after adding chlorine to confirm I am actually getting to SLAM level?
2. Could the 12.5% shock I bought at ACE Hardware be less than advertised?
3. I already started bringing the salt level up, when should I start brining the CYA levels up to TFP recommended levels?
4. Should I consider adding DE or buying a water clarifier to speed up the process if I am impatient and want it clear by the weekend?
5. Should I not backwash when pressure goes up 2-4 PSI as the extra debris in the sand filter will help clear up the cloudiness faster and let it get up higher?
Initial Test Results (TF-100 Pro) prior to SLAM:
FC - 0
CC- 0
pH - 7.5
CYA - 40
CH - 200
Salt - 2400
Temp - 56
Questions:.
FC - 0
CC- 0
pH - 7.5
CYA - 40
CH - 200
Salt - 2400
Temp - 56
