If those are aluminum...Your best bet would be to call your local siding and aluminum gutter contractors...the may be able to fab custom aluminum pieces...or if it happens to be galvanized sheetmetal (doubt it) your local Air conditioning contractor could fab galv sheetmetal. Hope this helps
I believe I have the same type pool where the liner wraps over a 2 x 6 or 2 x 8 and the cap covers where you staple the liner down. I am replacing the liner this year and plan on putting brick coping on top of the concrete blocks and switching over to a beaded liner. This may be an option for you if your ready to change liners. The brick will make a nice seat around the pool.
