Great! In general you will never need clarifiers, Floc, algaecide. There are special cases, but you likely will never encounter. They are not needed and many include stuff you don't want in your pool.
Here is the Safety Data Sheet SDS for this product:
https://assets.unilogcorp.com/187/ITEM/DOC/100013383_SDS.pdf
It contains this, which is basically polyquat. The single use this is good for is for closing your pool, even then there is debate.
Poly[oxy-1,2-ethanediyl(dimethyliminio)-1,2-ethane diyl(dimethyliminio)-1,2-ethanediyl dichloride
It also contains: Sodium tetraborate decahydrate
This is Borax. We use it to raise pH. Same stuff as 20 Mule Team Borax from the Laundry isle.
The big thing I was looking for is Copper. Many algaecides use Copper. It is a major No No in a pool for a lot of reasons. If you are ever going to buy anything we don't recommend, avoid anything with Copper or "Blu" or Blue in the name. If you get copper in the pool, only way to get rid of it is to drain.
Luckily neither of these chemicals should cause an issue...you should clear up. Keep slamming!
How is the SLAM going? We always love pics.
