Good morning, Draco.
Still couldn't find te msds for that trio of products but here's what I suspect each do:
1. This sounds like either ascorbic acid or citric acid
2. The pool refresh is a floccing agent
3. The liquid metal trap will be a sequestrant
What hydropure appears to have done is to have packaged the AA treatment we refer to at TFP and added a metal floccing element which isn't an entirely bad idea depending on the actual chemicals they're using to do so.
Please ask the rep if anything in the package is "negatively charged" -- some polymer-based sequestrants, like jacks Magenta, (but not purple) are. If anything is the package is negatively charged and you use Polyquat 60 to control for algae while your FC is low per treatment instructions, you will have a mess.
When you bring the FC back up from this treatment, I suspect you will find you need liquid chlorine to do so and make sure you've gotten up to level. Lots of folks who do the AA treatment don't realize that leftover Ascorbic acid literally eats chlorine until spent and sit to long at a low FC and then get algae.
If you end up having to slam/shock after this treatment, you will cause restaining and wear off the sequestrant. You will also need to closely control your ph to around 7.2 post-treatment to avoid restaining.
Another question for the rep is whether the stain remover and floc will actually work on already sequestered metals. Be sure to read for metal levels before application, then after the floc and vac-to-waste...before applying the sequestrant. That will be one way to tell if the floc component did anything. A second way to tell is if the floc removed iron, it will be tinted iron colored like this: (a picture from an Alum experiment on water from my well. Just so you know, a second bucket test on my sequestered pool water with same product failed completely, which is why the jury is out for me on this as a reliable removal method, but I had created high shock value conditions to see if I could precipitate the metal .)
When you do the treatment, do post your outcome. Knowing how things work out helps us help others
Good morning Swampwoman,
Thanks again for your reply! I agree with you that their "set" is really Ascorbic Acid, (floccing agent), and a sequesterant. Since I already had about 5 pounds of AA and 3 more bottles of Jack's Purple, I will be using that instead and only using their Pool Refresh to do the floccing.
I did buy 4 bottles of their Liquid Metal Trap though and will call the agent about it to inquire, thanks for the information!!
I also have a few more bottles of PolyQuat 60 on hand.
Here's what I'm going to do:
- Lower the pH to 7.2.
- Add a dose of PolyQuat 60.
- 2 Pounds of Ascorbic Acid.
- Circulate for around 4-5 hours (this works VERY quickly on my fiberglass).
- Add the Pool Refresh
- Filter non-stop for 24-48 hours.
- Backwash as the pressure rises (I hope I see the rise, since every time I would use Metal Magic or a similar product, I've NEVER seen it rise), but none of the other products were a floccing agent.
- After 48 hours, turn the filter off and let everything else settle to the ground.
- Vacuum the entire bottom to waste.
- Completely replace all sand / clean the filter.
- Slowly raise my FC to 3 PPM over the next 1-2 days.
- Add a quart of Jack's Purple and maintain regularly.
- Maintain pH of 7.2.
Going forward I will use your advice of doing the bucket test with my fill water. I have two Metal Traps now and I'm going to do the test with unfiltered and filtered water to ensure I'm capturing any new iron going into the pool.
I do hope that this Pool Refresh product will work. It supposedly removes all phosphates as well, which I think will help with keeping the algae bloom down during the treatment.
I will be doing it this weekend on Sunday and will be sure to report back.
Thanks again everyone!
