Edit: Since the my intellicenter thread and this one got merged, I'll put the intro/description of the construction thread up in this post (repeated below):
IntelliCenter post:
We have an IntelliCenter with Load Center for our pool install. The electrician is coming in next week to start running the electrical to the equipment room. Are there any reasons we *shouldn't* just use the IntelliCenter Load Center *as* the sub-panel from the house? Our pool builder doesn't use these (but I insisted) - and the electrician hasn't installed one. So his standard setup would be a feed from the house to the equipment room to a sub-panel that feeds the pump, gas heater, pool lights etc. He plans to run a 50a from the house panel out to the equipment room.
Given that the load-center can act as a sub-panel for non-pool items (like some additional plugs around the pool and landscape lighting) - should we just use that to save some money? Or are there benefits to just having a proper sub-panel between the house and the IntelliCenter (or drawbacks to just using the IntelliCenter)? I read in the manual that it's limited to 10 additional single-pole circuits. Which would be fine for what we are planning.
I'm a new member...but wanted to share the photos from our build! We own a small farm (2.4ac) on Vancouver Island (Canada). We decided to have an in-ground pool built in part of our field. It will be a 38x16 pool with a sun ledge on stairs. It's a steel frame with vinyl liner. Our pool builder picked all the equipment with the exception that I wanted an IntelliCenter so I could have a bit more automation control. Pool will be heated (propane) and will have a automatic cover (Coverstar) installed.
We got on the list with our builder in March 2022 (with an expected started in 2023). Engaged with a designer in fall 2022 to start planning the whole project. We finalized a design in early 2023, submitted permits to the municipality which finally got approved in May. We broke ground June 16. We are hoping to get the liner installed in September (weather permitting) - but if the liner doesn't arrive (or the weather doesn't cooperate) then we may have to wait until Spring 2024 for the liner.
IntelliCenter post:
