Hi,
I edited to reduce words.
Really quite happy that after 19 years I have my first panel leak.
Anyway - preferred repair method and contingency plans:
1. I saw the video on the Fafco repair kit and trimming out part of the diameter of individual tube and shoving plugs (1-2) at top and at bottom of channel. THAT is a lot of time on the roof with some risk of cutting adjacent tubes. Amazon Clinic
2. Use a Rainbird 1/4" connector after fully cutting the tube/channel and using this as a stent - seems simple, unless the tube pliability is lost due to age, or the connection just loosens with time (no reference to silicone sealer in this application)
3. If #2 fails though - I now have a cut tube -- would I use a 1/4 inch nylon bolt (head cut off) with added silicone caulk, put into each cut end? Or cut it all out and do these screws at the header and footer?
4. Screwing a stainless steel screw with silicone into the PCV header and footer?
5. FYI Fafco is 12 yr warranty per the installation company (saw 30 yrs in a thread here somewhere)
6. FYI saw a complaint about $65 for a service call for a leak - here in Cal, today, it is $206
